36-39 Gas tank decals
  • 36-39 Gas tank decals
    Is anyone making the 36 to 39 gas tank decals,
    that are like the original factory used?
    The originals seem to be a layered process,
    with silver as the base color.
    The new ones do not look the same as the
    old originals, when I wet sand them through
    to, match my old paint bike.
    Thanks Lee
    I had stickers made from vinyl that you can patina with scotch brite through the layers for the right look, I also made the patent decals in the same material.
    Carl
      There's one on ebay right now that claims to be NOS/OEM ... based on the photo, I'm a little skeptical of that, but you may want to check it out. I'm thinking the high bid to date was in the $20's.
      Vic Ephrem
      AMCA #2590
