Paint
  • VPH-D
    Paint
    Would like some opinions on what type of white paint was used on WPB civilian Knuckleheads. Was the paint used on tappet blocks and oil pumps flat, semi-gloss, or gloss?
    Is the top motor mount parkerized, or black?
    Ditto on the kicker spring?
    VPH-D
  • KNUCK
    I have an original black and white photo of a new 46' with this finish I will try to see if possible to tell. I am at work now.
    Have you checked the "big book"?
    • VPH-D
      I don't believe Palmer addresses the finish of the white paint.
      I've always thought the kicker spring were gloss black, but finding a parkerized spring in a box of parts started me wondering.
      VPH-D
      • VPH-D
        Anyone, Anyone?
        VPH-D
        • Matthew N. Olse
          The white paint was an off-white and it was glossy. The top motor mount was park, and the kicker spring was black. Use a tough paint on your white finishes, other wise the gasoline will take it right off.
          • VPH-D
            Matt,
            Thanks for the input. Would you recommend a spray paint mfg. and color? Is powder coat an alternative?
            VPH-D
            • Matthew N. Olse
              We use emron paint on our biks. It holds up well to the heat and gasoline. I matched the color to a n.o.s. scavenger pump that my dad had laying around. I dont know if there is a good spray paint out there that would work for your application. Buy a can that you think looks right and see if it holds up to gas before you finish your motor.
