Knucklehead cylinders
  • 68bagger
    member
    • Mar 2010
    • 23
    Is there a easy way to identify a 1946 rear cylinder from a front cylinder? 1946 FL. Thanks
    • 4789
    Rear cylinder has one relief in the fins for a pushrod cover, front has two. With the relief facing you the rod clearance notch on the skirt faces right. 61 cylinders have a fire ring on top, 74 do not.
    This is a rear.
    • droptopford
      • Jan 2010
      • 360
      Robbie, your knowledge never ceases to amaze me. And your willingness to dig out parts and take photos... much appreciated!
      • 68bagger
        member
        • Mar 2010
        • 23
        Robbie, Thank you for the picture and explanation. I finally got the cylinders back from the machine shop and the marks I had were gone.
