Carby identifcation
    Originally posted by macca View Post
    i have checked it & the flange .all so built up the manifold so it only just fits between the head & machined it true.I will put it back to original spec & see what happens
    I am confused, Macca,
    "Built up" means you welded or soldered something?
    A 'plumber's' manifold shouldn't be tight between the nipples;
    Have your heads been converted to O-ring?
    (The original width of most Knuck manifolds averaged about 3.410", with the rest of the gaps bridged by the seals.)
    Got any pics to help me understand, Thanks!
