1944 E at Mecum
Here is the link to view all registered Motorcycles lots for the Las Vegas...'Big Shoe' on 1-31-2026. *As per usual, some helluva nice sTuFf...
Upcoming Lots - Mecum Auctions
*M.A.D.*
*1944 E Knucklehead.Originally posted by Jdiesel25 View Post
*M.A.D.*
I can't ante up, Folks,
But I can bring reality back, while staying in my own lane of carbs and manifolds.
Looky at a wire tie instead of a choke lever assembly,
And a bodacious plume from a manifold leak to the front cylinder (at least):
Its a beautimous veteran! Seriously. Lovely.
But it will take even more cash to make it run right.,
....CottenLast edited by T. Cotten; 01-02-2026, 01:44 PM.AMCA #776
Cotten,Originally posted by T. Cotten View PostI can't ante up, Folks,
You are correct, they typically do take a amount of money to make them run and drive acceptable.
Note not only the front intake manifold tracing but the fact of a "new" blue graphite head gasket. That also tells a story yet to be learned...
I would give it better odds than a copper gasket, Duke!Originally posted by dukekleman View Post
....Note ...the .. "new" blue graphite head gasket. That also tells a story yet to be learned...
But I've been out of the game for decades.
PS: Is that a wire tie, or just a bent coathanger choke control?
I'll allow it.Last edited by T. Cotten; 01-02-2026, 07:01 PM.AMCA #776
And a bodacious plume from a manifold leak to the front cylinder (at least): Hilarious!
We were on a road run this year and a chap was having an awful time cold starting a freshly (untested) restored 48 Pan. It back fired, loud as a cannon, and briefly ran backwards. With both sides closed of throttle blade and choke, it essentially sealed the intake passages, the resulting eruption found the nearest avenue of escape, the aforementioned plume blew black heavily choked unburnt fuel all over one head and cylinder from a leaking spigot. His day was done before it even started.
I'll send you my cell # on a pm and if you want to meet up let me know. Likely a text is best as the place is so loud I usually have something stuck in my ears in the bid area.Originally posted by Jerry Wieland View Post
I'll be there.
Jerry#7558 Take me on and you take on the whole trailer park!
