Rocker shaft nuts
  • hoyt1967
    • Oct 2017
    • 23
    Rocker shaft nuts
    Assembling my EL heads, replacing the large chrome rocker shaft nuts, the new ones have an oring recessed into them for sealing. So the question do I eliminate the brass washer that normally goes between the nut and the rocker housing with this different style nut? Thanks
  • jorrow
    • Feb 2008
    • 347
    Yes, no need for the brass washer.
