Knucklehead front motor mount
  • sparky
    • Feb 2012
    • 12
    Can someone explain to me how the front motor mount with the right angle washer actually goes on properly
    This gallery has 2 photos.
    • 2024
    The hex nut fits in the recessed counter sink of the case motor mount under the generator. The pointy washer acts as the stop to prevent it from turning as there is no way to utilize a wrench with the generator in place. The bolt comes up from under the frame and the tin lock prevents the bolt from loosening. The bent edge of the washer goes up towards the frame and the bolt is tightened and then the tin washer is bent down to form an interference lock against the head of the bolt..
