Nickel plated parts
  • DANPATCH
    • Apr 2009
    • 313
    Nickel plated parts
    Is the timer strap 1627-36 Nickel plated .I have seen both ways on restored bike .Palmers book says Tank top bolts 3582-18 are Nickel 3532-18 .I could not find that part number.Were do these bolts go??
  • sswaney
    • 302
    3532-18 are the Top Tank Screws
    3582-18 do not appears in the 1935 Dealer Parts Catalog I have
    Sorry, no help on the timer strap finish.
    • sswaney
      • 302
        • 2044
        None of the timer straps in Palmer's books are black on civilian bikes.
        But were they low grade stainless & not nickel plated?
        • knucklehead 61
          • Sep 2016
          • 353
          3232-18 bolts secure the tanks to the top of the frame on all 1918-1936 bikes except 1936ohv, & will fit back to 1909.
          • DANPATCH
            • Apr 2009
            • 313
            tank top bolts 3532-18 are for 45 tank top plate and bolts
              • 2044
              4 straps,
              top is stainless aftermarket..no pull on magnet.
              next is black...blued spring steel & then either parkerized or painted black.strong pull on magnet [home made?]
              next is silver original..left side was rubbed on with cleaner,right is original patina..light pull on magnet
              bottom is one I made 40 years ago out of low grade stainless & sat in a drawer..it has a similar pull on magnet as the silver OEM
              What I call low grade stainless is 304 stainless & contains iron,to be malleable/workable
