1937 fender light routing
  • DANPATCH
    • Apr 2009
    • 313
    After leaving the tube in the front fender how is the wire ran for the front fender light . Were does it hook or get power from .
  • otis71
    • Jul 2015
    • 597
    I couldn’t find it in the wiring diagram but I routed my front fender light wire under the gas tank and to the headlight terminal under the instrument panel. The wire is barely visible and the light works with the headlight.
      • 4790
      The power should come from the terminal for the parking light/ taillight side of the switch. Then it is on whenever the headlights are on but also comes on when the switch is in the park position along with the tailight.
      • DANPATCH
        • Apr 2009
        • 313
        Thanks for the help.
