Help with my head
  • Old Ugly 40
    • Dec 2014
    • 88
    Help with my head
    The heads on my 40 EL are in rough shape but I have a pretty good set of 41 heads.
    Can I use the 40 rear rocker box on the 41 rear head?
    Thank you in advance.
    Rod
    #25781
    • 4790
    Yes, you can....
    • Old Ugly 40
      • Dec 2014
      • 88
      Thank you Rubone. You are the greatest.
      I assumed that I could but needed to be sure.
      Thanks again.
      Rod
      • Old Ugly 40
        • Dec 2014
        • 88
        Hi to all,
        I took both heads off my 40 EL today and noticed something unusual, Neither head has a date code that I can see. Does anyone have the answer to this mistery?
        Thank you for any input.
        Rod
        #25781
          • 2024
          Originally posted by Old Ugly 40 View Post
          Hi to all,
          Rod
          #25781
          Every OEM 1940 EL that I have worked on does NOT have date codes. I believe it is supposed to be that way.
          Jerry
          • Old Ugly 40
            • Dec 2014
            • 88
            Jerry,
            Thank you so much for your reply.
            Very interesring. I assume [ bad thing to do ] the heads only did not have date codes as my rocker boxes have B 9 and D 9 date codes. Did 36 -39 EL heads have date codes?
            It would be nice if more people with knowledge about this could chime in.
            Thank you again.
            Rod
            • RichO
              • Dec 2001
              • 903
              Check your belly #'s and you'll find they are the only ones with just an E.
              DrSprocket
                • 4790
                Jerry
                My guess is first year big port heads were made off a master mold, later productions were coded.
                • Old Ugly 40
                  • Dec 2014
                  • 88
                  RichO,
                  Thank you for your input. Another 40 EL oddity.
                  Rod
                  • Old Ugly 40
                    • Dec 2014
                    • 88
                    Rubone,
                    Once again, thank you for your knowledge and input.
                    This seems to be the most logical reason there were no date codes. But one has to think it would have been easier to track problems if they had used date codes.
                    God [H.D.] worked in mysterious ways.
                    Rod
                    • Old Ugly 40
                      • Dec 2014
                      • 88
                      Hi all.
                      This, I hope, 20230318_140733.jpg is a picture of a crack in my 40EL front head. Also has a heli-coil, the nipple was very loose. After removeing the rivet was able to easily remove the nipple and easily thread it back in and tighten it but could not get it to seal. The seat area looks like it was repaired with solder. The rivet hole is also way to big (3/16"-1/4"). Also the exhaust port has a threaded 3/16" to 1/4" hole.
                      Ending this post now and will post rear head problems and questions later.
                      Thank you.
                      Rod
                      • Old Ugly 40
                        • Dec 2014
                        • 88
                        Hi again.
                        Now rear head problems. 20230318_140535.jpg Crack in same area as front head and over sized rivet hole but not as bad as front head
                        When I presure tested this rivet leaked but the nipple was good. Tried to tighted the rivet with no luck. Tried makeing soft steel and aluminum rivets but couldn't get these to seal either. The exhaust port also has a taped hole.
                        Can these heads be repaired?
                        Thank you in advance for any advise.
                        Rod
