“1936” Knucklehead on EBay
  • Jdiesel25
    • Mar 2018
    • 295
    https://www.ebay.com/itm/38540277262...Bk9SR466v47JYQ
  • Jdiesel25
    • Mar 2018
    • 295
    Bad vin number
    • pmurray2287
      • Dec 2022
      • 22
      Originally posted by Jdiesel25 View Post
      Bad vin number
      Interesting, please explain for educational purposes.
      • Jdiesel25
        • Mar 2018
        • 295
        The characters are not consistent with factory HD stamping.
        I’ll upload a picture for comparison
        • pmurray2287
          • Dec 2022
          • 22
          Thanks the E is a dead giveaway...
          • Omarttentmaker
            • Dec 2009
            • 322
            Bad vin number
            In comparing the 2 pics, you wonder how this was accomplished. I don't seen any machining marks on the boss or the capture lugs for the speedo clip. I wonder what the belly numbers look like? Think this may be a factory replacement case?
              Here is a link showing what numbers should or should not look like, https://vintageamericanmotorcycles.com/v/Numbers/
              • Matt58
                • Apr 2021
                • 2
                Chris one of those in your link IS the ebay one....
                • dukekleman
                  • Jul 2022
                  • 596
                  Was there a Mid-year production change made in the crankcase castings? My reason for asking is that I've seen some 36' EL's that do not have the casting tabs for the anti-rotational speedometer cable clip. Or are those incorrect crankcases re-stamped?
                    • 2024
                    Only the very earliest 36 did not have the tabs for the speedometer clips.
                      • 2024
                      To me the 6 is the obvious culprit.
                      • Speeding Big Twin
                        • Mar 2010
                        • 433
                        I asked the seller for a photo of the BNs but I received no reply.
                        Eric
                        • Speeding Big Twin
                          • Mar 2010
                          • 433
                          For 1936 Knuckleheads the earliest I’ve seen the two nubs are four cases with SN 12++. But that doesn’t mean all cases with higher SNs had them. Most probably did but some didn’t. For example I have photos of seven with SN 15++ but only six have nubs. And I have photos of four with SN 21++ but only three have nubs.
                          Eric
                          • Speeding Big Twin
                            • Mar 2010
                            • 433
                            Once again I see a link to case numbers on VAM and as usual those pages contain some SNs that are not consistent with factory stamping yet they are not described as such. For example 39EL1414, 41FL3553 and 47EL13649. And there are several others as I’ve said over the years on one site or another.
                            Eric
                            • dukekleman
                              • Jul 2022
                              • 596
                              Eric and Jerry, Thanks for the reply.
                              ​​​​​ Yes it's strange to me because I've seen and have photos of vin number 27XX without the casting tab bosses. I know there is plenty of stuff out there posing as something it isn't.
