feeding tail light wiring through channel in rear fender
  • DANPATCH
    • Apr 2009
    • 313
    any tricks on getting the wire run in the rear fender
  • silver65
    • Nov 2020
    • 176
    Install a pull wire preferably a solid one bend a small loop on end attach striped wires a little black tape and a little dish soap as a lubricant don't make the head larger than the raceway.
      • 4790
      Keep in mind it is just the wires, too, no sheath.
      • DANPATCH
        • Apr 2009
        • 313
        Take a piece of 14 gauge vinyl wiring and run it through the hinge end of the fender. It takes a couple of attempts. when you get it all the way through to the other end or front of the fender strip a little off and do the same thing for you cloth wires and solder them together. and pull them through.IT helps to grind anything on the solder that will cause problems..Do not use electrical tape that is what was causing the problems. The tape made a little bulge and the the wires would not pull through.
