Rocker shaft seal
  • otis71
    • Jul 2015
    • 597
    Rocker shaft seal
    Can the rocker shaft seals 17475-38 be replaced without pulling the shaft covers? If yes it appears it can be a quick job without removing the gas tanks. Thanks for any advice.
    • 4790
    Short answer is NO! And the easiest and most foolproof way to get them right is with the heads on the bench.
    • otis71
      • Jul 2015
      • 597
      Can you give me a quick description of the job? Service manual doesn’t have anything on it. Thanks
        • 4790
        I tried to respond to your visitor message but I cannot even open it. The system isn't working apparently.
        • otis71
          • Jul 2015
          • 597
          Can you post it publicly or try again sometime? Thanks
