Outer diamond primary
  • pan620
    replied
    Originally posted by Chris Haynes View Post
    As far as judging on a restored machine goes, if it is the best reproduction available it is fine.
    So what is the best reproduction that is available
  • EricOlson
    replied
    Here's a picture showing the area Robbie is talking about. You can see the difference circled in red.
  • Chris Haynes
    replied
  • Jerry Wieland
    replied
    Originally posted by larry View Post
    Has anyone ever reproduced a cover with the correct dome?
    If someone has I have never seen it. Jerry
  • larry
    replied
  • Rubone
    replied
    The way the diamond is stamped is one thing, the depth and shape of the sprocket clearance is another. Originals have a pronounced radius where the diamond meets the domes, aftermarket are straight. The front sprocket stamping is a very shallow domed area, aftermarket are taller and more square sided.
  • DANPATCH
    started a topic Outer diamond primary
    How do you tell the Outer diamond primary original from reproduction .I thought it has something to do with how the diamond was stamped.
