Knucklehead/ big flat front brake drum ID help
  • MMasa
    • 1192
    I have what appears to be a -41 cast front brake drum but it has two square lugs cast into the outside face near the outside diameter. Is this an oddball for a certain year or range of years or maybe a later replacement parts counter style?
    probably a simple question but knuckleheads are a bit outside of my wheelhouse.
    Thanks for any help you can offer.
    Mark Masa
    Mark Masa
    www.linkcycles.com
    • 2024
    Mark
    I have seen the drum as you mention but have I not really been able to id it. Lugs look like what are on a Hydra-Glide drum so I have always assumed that it is a later replacement or maybe OEM for later Servi-Car. The 1941 casting number has always thrown me for a loop as the cast drum actually started in 1940.
    Jerry
    • MMasa
      • 1192
      Thanks Jerry
      Mark Masa
      www.linkcycles.com
