Front wheel question
  • projectstarter
    • Sep 2020
    • 77
    I have a 1947 FL and when the bike is on the lift with the front wheel in the vise, there is a little bit of movement or play at the wheel hub. I noticed it when I was holding onto the handlebars while I was strapping the bike to the lift. I'm guessing there is too much end play in the wheel hub? Has anyone else had this?
    • 4790
    Yes, everyone with a star hub wheel. The end play and roller fit are regular maintenance and wear items to keep up with. If there is a rocking motion it is most likely bearing fit.
    • projectstarter
      • Sep 2020
      • 77
      Thank you Rubone for the reply. The motorcycle is a restored bike with only 8 miles on it since the restoration. I'm going to have to take that hub apart and see what loose.
        • 4790
        Is it an OEM or aftermarket hub? Some replacement types are set up wrong when new.
        • projectstarter
          • Sep 2020
          • 77
          It's an OEM wheel and hub with stainless spokes.
          • 41craig
            • Nov 2010
            • 410
            Restored doesn't always mean that everything on the bike was restored. A lot of times it means that sheetmetal , the motor and transmission have been rebuilt and restored. It's always a good idea to give everything a once over. Even from trusted sellers.
            • projectstarter
              • Sep 2020
              • 77
              The wheels have definitely been rebuilt, I think someone overlooked something when the put it back together. I just want to get it right so i can ride it.
