24800-36 Placement
  • otis71
    • Jul 2015
    • 597
    24800-36 Placement
    inquiring about the proper placement for 24800-36 motor bolt lock washer. It seems the only way it can go is underneath on the bolt head with the lip up catching on the skid plate. I don’t see how it locks anything in this position so correct me if I’m wrong.
    • 4790
    Once the bolt is tight you need to bend up the other side against a flat on the bolt head to make it lock. It does not do it all by itself.
