Linkert Nozzle Identification
  • otis71
    • Jul 2015
    • 597
    Does anyone know what this nozzle is? Looks similar to 1258-36 but differs slightly. I’m not sure it’s Harley.
    My best guess, Otis,,...
    Is (late edit: It started out as...) 1248-41 (27331-41) for M45s and M75s.
    Shown on the right; Note yours has a longer spigot and shorter collar beneath it, which was proper for nearly all 1 1/2" Models.
    Perhaps somebody turned it to allow the spigot to approach the center of the venturi, as it should!
    PS: The Harley-model signature of the enigmatic discharge channel at the top has been also removed, perhaps.
    Can you gauge the bleed holes and bore with drill bits?
