S&S flywheel
  • hdhikaru
    • Feb 2010
    • 217
    S&S flywheel
    Hi
    I just pull this flywheel off 46FL knucklehdad.
    can anyone tell this is stock or stroker ? and please how do you ID,
    tks
    Shin
    • 2024
    This information used to be available in an S&S catalog. Sorry but I do not remember how to decipher that number. Maybe call S&S Tech Support. Judging by the location of the wristpin I would guess not.
    Jerry
    Originally posted by hdhikaru View Post
    Hi
    tks
    Shin
      • 4790
      Shin, the measurement between the shaft centers is 1/2 of the stroke. It is easy to tell. Standard H-D stroke is 3-1/2" for EL, 3-31/32" for FL.
      • kitabel
        • Sep 2018
        • 471
        14E is a 1936-54 big twin roller bearing flywheel in 3-31/32" (FL) stroke and 8-1/2" diameter.
        The Linkert Book
        • kitabel
          • Sep 2018
          • 471
          If it has confusing or no markings, measuring between the shaft center and pin center X 2 is correct, but the exact center is tough to find if the shafts are still in, and it's a bit vague if they're not.
          Another way:
          1. measure from the outside of both tapers and inside of both tapers
          2. add them
          3. equals stroke
          The Linkert Book
          • hdhikaru
            • Feb 2010
            • 217
            thank you guys! just checked the S&S they said its stock. I've never used S&S stuff before... what you guys think about S&S ? better than other bland like V-twin?
            or better than the original? can expect good performance? tks Shin
              The quality of S&S products is legendary, Shin!
              But beware their flywheels have less mass.
              This is better than 'stock' for a light machine desiring acceleration and a peaked powerband.
              But suffers with a heavy payload (especially a sidecar, even stroked.)
              ,,,.Cotten
              • 41craig
                • Nov 2010
                • 410
                With the lightweight flywheels, you'll have to slip your clutch from the stop sign. I know this from shaving the flywheels on my big twin flathead 47 years ago. Nothing wrong with S&S. They've one heck of a reputation.
                  • 2024
                  I do not care for S&S flywheels because they are steel and can be very hard to true and also as Cotten says they have less mass. S&S as a rule has good parts but I prefer stock or Truet&Osborne flywheels. That being said I have a stroked 47 knuckle with S&S but next time I would use T&O.
                  Jerry
                    Jerry
                    They certainly take a different technique, no doubt, Jerry!
                    And my preferences are similar, but S&S wheels are still desireable, especially if you want to build a screamer.
                    Truing S&S wheels then made the new evos familiar to me, as neither could ever be tapped with a mallet, or it would just spring back out-of-true the opposite direction, and then spring back where it was if tapped the other way. (Using a mallet is only a measure of one's lack of patience anyway, but I admit to it.)
                    Once I started lapping every taper between centers on the lathe, truing became much, much more rewarding.
