Cycler inside wiring lamp holder to reflector
  • Cycler inside wiring lamp holder to reflector
    Having trouble installing the cycler inside wiring lamp holder-socket-to the reflector. The 3 spring loaded pins are basically the same size as the opening and to get into the slots I do not want to bend or break the assembly, can get 2 in but the third is even with the slot, therefore cannot fit over to slide back in. Any help would be appreciated. Thanks
