Ebay Linkert M-5 With Repairs
  • 41craig
    • Nov 2010
    • 410
    I found a Linkert ( Possibly M-5 ) carb. body with bushings installed for the choke shaft and a plug in the air bleed on the idle side. Why the plug ??
    https://www.ebay.com/itm/Vintage-Har...QAAOSwK21e-p0q
    Craig
    • 8234
    Craig
    T'aint no M-5, Craig!
    (L&L script, and not faced on the bottom for a doweled OHV bowl.)
    Bushing the choke shaft is no big deal; But it looks like the side-vent has a peened plug: Good eye!
    Must have run an Indian or military HD model venturi.
    PS: It might just be the pic, but the bowlstem gallery plug holes look hogged.
    • 41craig
      • Nov 2010
      • 410
      Maybe an M-51. It might have trouble with the idle after looking at the stop on top.
      Craig
        • 8234
        That's an easy silver-solder repair, Craig!
        The enormous bore wear from the throttle disc is the real idle problem.
