1938 Horn Assembly to Fork
  • slamiste
    • Mar 2010
    • 260
    Can anyone supply an exploded view of the horn to fork assembly for a 1938 big twin? My parts books only have the view for the later version. I checked the virtual library and didn't see anything there that shows the view I'm looking for.
    Steve Slaminko
    What exactly are you looking for? It is a pretty straight foreword install. The '38 used a horn with to bracket riveted to the back. The mountings attached to the screws that hold the horn together, The rubber on top and spring plates on the bottom.
    • slamiste
      • Mar 2010
      • 260
      Chris,
      I was hoping to have the exploded view to make sure I get the correct hardware and also to insure I get the whole thing assembled properly. Palmer gives a pretty good description of the assembly. I will be able to get it assembled but if a illustration exists I'd like to see if.
      Thanks!
        It connects to the fender at the bottom and the fork spring perch on top. Thanks Robbie.
          • 4790
          It doesn't attach to the handlebars, it attaches to the fork spring perch.
          • slamiste
            • Mar 2010
            • 260
            Chris and Robbie,
            Thanks guys. Picture is a big help. Your help with my many questions over the years is always appreciated.
            Steve Slaminko
            • steve marxen
              • May 2013
              • 31
              I will never remember what little I did know but isn't that the wrong horn?
                • 4790
                Chris's picture is to show the mounting. He wasn't trying to picture a 9 bolt horn.
                  It is now. But it won't be after 3 holes are installed.
