NOS Knucklehaed cases value?
    • 2044
    NOS Knuck cases,long rib,no VIN stamp,bottom numbers are just 2 digits.
    Were these 1950s production replacement cases?
    What is the value of these?
    • 4790
    The date codes will tell you when they were made. The 2 digit code is standard for replacement cases, they should match which means they are a line bored set. Full belly numbers only appear on complete engines. And they could date from the '40s to '50s. As to value they are likely about 5K if in new condition.
      • 2044
      Thanx Robbie,I haven't seen them to look for the codes,just asking for friend.Price sounds right to me.These have the bag of pieces that came with them from the factory inside,bolted together.
