Need advice, 61" Knuck cylinders on a 74"
  • Need advice, 61" Knuck cylinders on a 74"
    I have a very nice set of late 5 fin 61" Knucklehead cylinders that have been bored out to 74" standard bore.
    What are the pros and cons of using them on my 47 74" bottom end?
    Obviously the compression bumps because they are about a 1/16"?? shorter.
    Does using low or medium compression pistons bring it back down to the standard high compression ratio?
    I have some +0.060" 74" 5 fin cylinders that I could use but these 61" have no fin damage at all, have correct and matching date codes for my engine VIN.
    What's the value of 61" cylinders compared to 74"?
    These could always be sleeved and brought back to being VERY NICE 61" cylinders.
    Thanks in advance for your input.
    Mark Masa
    Mark Masa
    www.linkcycles.com
    The height difference is .125" (5.530" vs. 5.405"), which may cause piston to valve or piston to head contact.
    The Linkert Book
      Mark!
      Were the over-bored cylinders fitted for pistons while stress-plated?
