knuck pistons
  • Colonel-46-El
    • Oct 2014
    • 43
    knuck pistons
    please,anybody what's difference between "36-40''41-47"(61)OEM pistons thank you the Colonel.
  • kitabel
    • Sep 2018
    • 471
    AFAIK the ring lands & grooves and the ring set. The later is preferred, but I'm not sure w/r/t the "female rod in front" etc. oil control thing. If you have a '46 you should be using the later pistons.
    IIRC the 1936-39 EL uses the same ring set (but not pistons) as the 1937-? U/UL, same bore size.
    The Linkert Book
