knucklehead kicker cover numbers
  • 41craig
    • Nov 2010
    • 410
    Originally posted by Speeding Big Twin View Post
    Thanks for posting but I’m not surprised there are no numbers on top of the rear mount of an EL. Some say the number 6 was used there to indicate E/EL but I found no evidence to support that story. AFAIK the factory didn’t stamp anything on top of the rear mount to indicate E/EL.
    Just out of curiosity, has your R-H case got anything stamped on the side of the relay bracket boss? Perhaps T or C?
    Eric
    Eric; There is nothing stamped on the relay boss. Maybe it is that my motor is a late 1950 production ?CIMG1374.JPG
    Craig
    • Speeding Big Twin
      • Mar 2010
      • 433
      Thanks Craig. I have nine examples of T in that position. One is on a case with a high 1949 BN and the other eight are on 1950 models. The T above is on a case with BN 350-1+++ and another also has 350-1+++. Two have 150-5+++ while another has 150-7+++. I don’t know the BNs for the remaining 1950 models.
      The C above is on a 52 model and I’ve also seen it on another 52 and a 51.
      Eric
      • nukkel
        • Jul 2017
        • 38
        Was looking for a 1941 cover and found this one:
        Some work to be done on the fill plug threads and the usual cracks around the starter crank ..
        I think those grinding marks on the outside near the data tag are typical as they can be found on others as well..
        Rein
        • 41craig
          • Nov 2010
          • 410
          Rein; That is a good cover and the repairs are easy for a competent welder and machinist. And it will be good for another 70 + years.
          Craig
          • nukkel
            • Jul 2017
            • 38
            Thanks Craig,
            Happy with it, unpolished and overseable repairs!
            Ordered an affordable tap to do the threads:
            https://www.ebay.com/itm/7-8-High-Sp...72.m2749.l2649
            Rein
