38 frame identification ①
  • hdhikaru
    • Feb 2010
    • 217
    Hi here、
    any idea..?
    this is a 38 frame I was told. I realized some #s on it... please refer the pics attached.
    looks 404.. 202...4... these are original stamp or what? please advice.
    tks
    Shin
    I have a 1938 frame here with a UL motor in it. Bruce Palmer's book was most useful in dating it. It has the closed end axle clips, no dent under the frame to clear the later 74 cubic inch cylinder heads, and no die numbers on the engine mount forgings.
    • Steve Little
      • Apr 2008
      • 915
      Hi Shin. The casting numbers look original Harley but your not showing the parts that will define a 38 frame. Is the left axle carrier undercut in the machining of the axle slide. Does the left axle carrier have a cap tack welded on the end. There's more info that the experts could give but if you post a pick of the left axle carrier and maybe left side of the neck and the cross braces under the oil pump, you'll get knowledge from some of the people who know.
      Steve Little
      Upper Yarra Valley. Victoria.
      Australia.
      AMCA member 1950
        • 4790
        The dash/speedo mount has been replaced. Those are also non-standard welds by the rear stays to top tube.
        • larry
          • May 2009
          • 247
          I have what I've always believed to be a '38 frame. The left axel carrier has a welded cap at the brake anchor. I don't understand the meaning of "undercut".
          • Steve Little
            • Apr 2008
            • 915
            Hi Larry.
            If you clean the road grime off the part you have pictured, you will be able to see that instead of a raised axle slide, (the area that the axle slides along) it is undercut. The machinist has cut it away and the machining is undercut into the part.
            Regards Steve.
            Steve Little
            Australia.
            AMCA member 1950
            • Sargehere
              Member since 1972
              • Jul 2006
              • 971
              Show a pic of the other side of the left axle carrier in your Post #5. Q is about how it's machined on the other side.
              Gerry Lyons #607
              http://www.37ul.com/
              • hdhikaru
                • Feb 2010
                • 217
                thank you guys! any advice about the#s 404..... ? please take a look closely..
                • hdhikaru
                  • Feb 2010
                  • 217
                  how about this sidecar loop. looks original to me but no casting#. grind off or repop..?? advice please. Shin
                  • larry
                    • May 2009
                    • 247
                    There is no raised portion at the axel slide. It appears to be as forged.
                    The inside surfaced is raised.
                    • knucklehead 61
                      • Sep 2016
                      • 353
                      a 38 toolbox mount will have rectangular blocks for the mounting bolts where a 36 & 37 are round.
                        • 2024
                        I think it is the other way around.
                        • Steve Little
                          • Apr 2008
                          • 915
                          Hi Larry. There is a lot of years of corrosion that has mottled the evidence of machining marks. The area where the axle adjuster hole comes through the rib, still has the semi circular pattern of the slab mill that was used during the machining process. Regards Steve.
                          Steve Little
                          Australia.
                          AMCA member 1950
                          • larry
                            • May 2009
                            • 247
                            Thanks for the explanation. I have another '38 frame. You can barely see the undercut, but it is certainly there.
                            • knucklehead 61
                              • Sep 2016
                              • 353
                              you are correct, i was mixed up. i had to take a look at my 37u & 48el frames again.
