What size hole ?
  • Old Ugly 40
    • Dec 2014
    • 88
    What size hole ?
    What size should the hole be in the frame tab for the inner primary mount on a 40 EL?
    Should it be a bit bigger than the bolt to allow for movement or variance or the size of the bolt?
    Thank you in advance.
    Old Ugly 40
  • 1950Panhead
    • Jun 2010
    • 343
    The frame tab slot is .437" long and .350" high, the bolt and spring let the cover flex.
    • Old Ugly 40
      • Dec 2014
      • 88
      Thank you 1950Panhead.
      I was just looking through my 1936-48 Parts Catalog (the one with the black cover) And don,t see an image of this bolt and hardware. (page 77) Is it the same as the one for the front of the rear chain guard?
      Thanks again.
      Old Ugly 40
      25781
      • Rollo
        • Nov 2008
        • 599
        And the oil tank tab! All three are covered by one bolt with hole for cotter pin drilled thru it, with the two flat washers ,spring nut and cotter pin.
        Tom (Rollo) Hardy
        AMCA #12766
        • Rollo
          • Nov 2008
          • 599
          Sorry that is for the upper not the frame tab or lower one.
          Tom (Rollo) Hardy
          AMCA #12766
          • 1950Panhead
            • Jun 2010
            • 343
            https://www.ebay.com/itm/Harley-Knuc...gAAOSwPc9WxR1z
            • Old Ugly 40
              • Dec 2014
              • 88
              OK !!
              Thanks guys. Got it figured out now. Will probably have more holy questions later.
              Old Ugly 40
              25781
