Good # or otherwise??
41 vin #
Tags: None
I used to know TIGmeisters who did much, much better, Jerry!Originally posted by Jerry Wieland View PostChris Someone did a repair with out getting into the serial number - that's tricky. Weld is a bit porous but probably will hold.
Jerry
But one died, another got old and cranky.
The lone survivor is tired of my loser gigs.
So now everybody's a welder; An associate brought me a right case with MIG work from a local speed shop that looked like a bird's nest.
PS: The repaired crack to the right of the number boss is painfully typical.
I blame it on the design of the baffle insideLast edited by T. Cotten; 02-15-2019, 12:27 PM.AMCA #776
I suspect the OP pic is of a factory replacement case for 41 and the old vin was stamped in to the replacement case. Not uncommon on 41 cases especially F and FL models. Unfortunately as Chris points out wrong font especially the 4 and the 1 and the 3 look to be the earlier style. May still be legit if done by HD shop and old case was surrendered. JMHO
Tom (Rollo) Hardy
AMCA #12766
I do better Cotton. Probably arc welded and not TIG. Jerry
Originally posted by T. Cotten View PostI used to know TIGmeisters who did much, much better, Jerry!
I blame it on the design of the baffle insideLast edited by Jerry Wieland; 02-15-2019, 07:25 PM.
Regretfully unless the seller has original documentation as to replacement cases or other reasons (dealer invoice, etc) it is merely a re-stamped case and the value is greatly reduced unless just for a rider , as a collector piece it is not good. It all comes down to what you want it for.Robbie Knight Amca #2736
The seller is David Wasserman.Be sure to visit;
