42 and 45 frame
  • hdhikaru
    • Feb 2010
    • 217
    42 and 45 frame
    any advice.... please.
    what the defference between 42 and 45 frame? or basically same? .. upto 46?
    tks
    Shin
    • 4790
    The biggest difference is that '42 to early '45 was still a brazed frame while later '45 was a mostly electric welded frame. All the neck and rear axle plate die numbers are different on them as well.
    • hdhikaru
      • Feb 2010
      • 217
      thanks! ... so other than cast# , fraze ,,
      they are same shape like.. neck angle, the loop shape and such??
        • 4790
        Yes, the neck angle and all mounts, tabs, etc, are the same.
          Factory blueprints put October 1944 as the beginning of Electric Welded frames.
