Big twin counter shaft speedo gear.
  • Steve Little
    • Apr 2008
    • 915
    Does anyone know if the speedo drive gear #35635-36 is being re-produced?
    The gear I am describing is pressed onto the counter shaft gear set for big twins, and the production period I am looking for is 1936 to 61.
    For some reason the 58-68 part manual I have, describes a period as 41-61.
    If the part is available, are there any problems with it.
    Regards Steve
    Steve Little
    Upper Yarra Valley. Victoria.
    Australia.
    AMCA member 1950
    Steve, V Twin had them. How good is any ones guess. I think you should have the seven tooth. In 62 the ratio changed and the gear had more teeth. They were stacked after being put on at the factory. If you look at an original you'll see little square divets on the sides. I just tack weld them in a couple of places. Never had a problem. Bob L
    • Steve Little
      • Apr 2008
      • 915
      Thanks Bob.
      I will enquire with our local V-Twin stockist.
      Steve Little
      Australia.
      AMCA member 1950
