Complete knucklehead heads from Tedd's V-twin.
    • 2019
    A friend recently bought a set of assembled 1940 to 1947 knuckle heads from Tedd and we are wondering if a guy can 'put them on and runn'em' or are there things we need to check first?
    Jerry
    • 5950
    Check anything before you use it.
    • vph-d
      • 1088
      Anything from V-Twin with moving parts. Probably those without moving parts, too!
      VPH-D
      • Tom O'Ryan
        • Jun 2015
        • 3
        Knucklehead Theology did a review on those heads. You might want to read what he had to say http://knuckleheadtheology.blogspot....klehead%20Tech
        • kitabel
          • Sep 2018
          • 471
          My concern with anything from Ted would be linear to my opinion of his business ethics.
          The Linkert Book
          • FNG1
            • Oct 2014
            • 201
            thanks for the link Tom O', great read. I am using older but unused VTwin heads and cylinders that came with my 41FL.
            • KNUCK
              • 826
              I would say a must read here. This would be a product that could be used if re worked by a pro shop to make it function properly.
              • FNG1
                • Oct 2014
                • 201
                Just like anything else, new, used, or repop. The heads I got with my pile of parts have already been gone over. One issue I had was just over a 1/8" gap between the heads and an aftermarket manifold. I turned two rings 1/16" by the O.D. and I.D. of the manifold and slipped them into the seals to keep the manifold centered.
                • Rollo
                  • Nov 2008
                  • 599
                  Sure you don't have 61 and 74 parts mixed up in there? The 61 manifold is shorter and the cylinders are shorter. Might have 74 cylinders and 61 manifold. Just asking.
                  Tom (Rollo) Hardy
                  AMCA #12766
                  • FNG1
                    • Oct 2014
                    • 201
                    Hi Rollo, the manifold is 3 9/16"
                      • 8233
                      FNG1!
                      It looks like a Colony manifold.
                      An eighth inch on each side works with properly fitted PEEK seals. No spacers necessary.
                      I'd bubble-test the inlet nipples and whatever that is for a rivet before I worried about the manifold width...
                      Good luck,
                      • FNG1
                        • Oct 2014
                        • 201
                        Hi Cotton, thanks, I am putting together a pressure tester today. How much pressure, 5, 10, 15 PSI? All of my bikes had spigots, (Triumph), rubber bands or O rings and were checked with carb cleaner or an unlit propane torch after startup. I have almost no experience with plumbers style manifolds. Thanks for any input. Should I use any sealant, or silicone grease, or just clean brass. Not going with peek unless I have issues, or is that what everyone uses? Should (or can) you anneal the brass.
                        • FNG1
                          • Oct 2014
                          • 201
                          I did the pressure test and it looks like the front head to the intake nipple leaks.
                            • 8233
                            Originally posted by FNG1 View Post
                            Hi Cotton, thanks, I am putting together a pressure tester today. How much pressure, 5, 10, 15 PSI? All of my bikes had spigots, (Triumph), rubber bands or O rings and were checked with carb cleaner or an unlit propane torch after startup. I have almost no experience with plumbers style manifolds. Thanks for any input. Should I use any sealant, or silicone grease, or just clean brass. Not going with peek unless I have issues, or is that what everyone uses? Should (or can) you anneal the brass.]
                            FNG1!
                            15 is the perfect overkill.
                            But it must be a constant 15, not trapped by a Schrader valve. Some leakage is to be expected, and your regulator must be allowed to compensate.
                            Please remove the heavy hardware from your plate and install a simple nipple that can accept light vinyl tubing. It makes it much easier to keep the manifold from moving after it has been lightly tightened while mated to the carb.
                            (The un-lit torch is the only practical way to find leaks between carb and manifold, or throttle bushing play,.. big ones anyway.)
                            Grease (or messy anti-seize) was traditional for brass ferrules.
                            Same for PEEK.
                            Brass can be annealed maybe.
                            PEEK works maybe.
                            PS: I'm surprised that's the only leak!
                            • FNG1
                              • Oct 2014
                              • 201
                              Hi Cotton, thats it just, the one leak. Ok, I used 3 PSI constant. I plugged the exhaust and intake and it is the nipple. Now what? I read to remove the rivet and tighten the nipple more. what if i can't get past the old rivet hole? should I cut multiple slits in it and try to collapse it? Would heat help to remove it? Thanks for all the help.
