Short ribbed/ Long ribbed cases 1941 BT cases
  • Paultrehberg
    • Nov 2015
    • 62
    At what time in the 41 production year did the BT cases go from short rib to the long rib ??
  • Matt McManus
    • Dec 2007
    • 142
    Very very late in the production year, around the 6000 VIN range.
    I had a 41FL58?? and it was still short rib. I have another 41 that is long rib its 41E6200, that the highest 41 VIN I have ever seen, has May 41 date code on the inside of the case. The factory long rib 41's are rarely seen, most 41's that at long rib have had the left case replaced at some point.
      • 2024
      I've looked at hundreds of 41 OHV cases and only 3 were long ribbed and Matt's is one of them.
      Jerry
        My 4,000 range FL case has short ribs. And yes it is broken.
        • nukkel
          • Jul 2017
          • 38
          Mine is 41EL612x and has long ribs as well..
          Rein
            • 4790
            My 41EL55XX=short ribs. MMMMM, short ribs!!
            • Paultrehberg
              • Nov 2015
              • 62
              How is it there are often long ribbed BT bikes on ebay with low serial numbers.??
                • 4790
                Cases regularly failed in '40-'41 and were replaced. That is the diplomatic answer...
                  • 2024
                  ...and probably true a lot of the time.. Jerry
                  • Spag
                    • Dec 2001
                    • 186
                    Were 1941 short rib cases used as replacement cases from the factory or dealer stock for the short rib ones (1941) that blew up or was the cause of the damage related to a cause other than a defect in the left-side cases?
                    Richard
                    Richard Spagnolli
                    AMCA #6153
                      • 4790
                      If a dealer had a set of blank cases he may have used them for a repair but if he had to order a set they were most likely long rib as the factory didn't replace the 40/41 short rib with another short rib. The casting date would be a good place to look. On an EL could be a different story as they weren't breaking as much as the FL. The problem was caused by the move to the large OD flywheels and consequent thinning of the cases. My best guess is that each issue was dealt with differently by dealers and owners. Lots were just welded up.
