M-35 Main Jet
  • billpedalino
    • Mar 2005
    • 1096
    M-35 Main Jet
    I rebuilt and installed an M-35 carburetor on my 1947 FL a couple of months ago. I generally install a No. 18 main jet in my Linkert carbs. to ensure a rich mixture at high speed operation. I have not run the bike yet and won't start it until the spring.
    After installing the unit on the bike, I looked at Palmer's data charts and noticed that the M-35 didn't have a main jet installed. Now I'm thinking that if these carburetors were meant to draw their high speed volume through the open hole with no jet at all, will I be running too lean with the No. 18 fixed jet, or can the jet remain, as it is standard on in the later M-36, M-36B, M-61B and M-74 units?
    Thanks...
    Bill Pedalino
    Huntington, New York
    AMCA 6755
    • 8234
    Bill!
    Fuel is metered by the HS needle in its seat on an M35, not an 'open' hole.
    The galleries should be plugged.
    Your HS needle should have a 45º point. (Later civilian carburetors that used fixed jets had a 22º point, with a much smaller seat.)
    With an extra fuel source, your needle's control would be defeated.
    PS: These things are sure forgiving, ain't they!
    • billpedalino
      • Mar 2005
      • 1096
      Thank you Tom - that's good information...
      I'll re-install the 2nd plug.
      Bill!
      Bill Pedalino
      AMCA 6755
      • knuckleheadtim
        • Jan 2008
        • 141
        Also, the M-74B uses an entirely different main nozzle which supplies more air to better emulsify the fuel. Therefore, a fixed main jet was added to balance out the fuel.
