Brake Cable Anchor Stud
  • Holeshotbob
    • Feb 2017
    • 76
    Can anyone offer guidance on what is involved with replacing a brake cable anchor stud on a Knuckle front brake plate? Do you drill out the old one or grind off the mushroomed over part on the inside? It could then be pulled or pressed out? Then the new one, do you press it in? How do you create the new mushroom to secure it? I have seen the replacement anchors but want to know what is involved before I would attempt a replacement. Thanks, Bob
    • 2024
    Bob
    It might be a light press but it needs to 'peened' like the old original one. The 'mushroom' you speak of is actually the peened head.
    Jerry
    • larry
      • May 2009
      • 247
      Is it destroyed or just loose?
      • Holeshotbob
        • Feb 2017
        • 76
        Pretty mutilated, it needs to be replaced.
        If it has to be peened in place, what would be the best method?
          • 2024
          Bob
          I have peened them with a hammer but it does not look like the original did but holds up. Jerry
