1941 FL Fuel Shut-off
  • eubanks
    • Aug 2017
    • 9
    I'm new to this forum and tried to perform a search for this topic. I apologize if it has been covered a million times before.
    My 41 FL is not shutting off the fuel. I don't think it is an alignment problem. My bike is very original and I would like to keep it that way as much as possible. That being said, is there a fuel shutoff assembly I can use to replace the leaking stock assembly that allows me to use my original shut-off operating knobs?
    My original shut-off operating knob is solid and does not have the small operating knob screw through the top. Most kits I see have the wrong type of knob.
    Any advice would be greatly appreciated.
    Sam
  • 1950Panhead
    • Jun 2010
    • 343
    The original knob was attached to the rod with a small screw, if yours differs it is not original.
    You could watch ebay for an original, this is risky as the rod or seat may leak.
    vtwin sells a replica 38-0232
    • eubanks
      • Aug 2017
      • 9
      thanks for the info. It is very possible that the knob I'm using was replace a long time ago. here is a photo of the knob:
      It has a lot of wear so I assumed.... You know what they say.... I am very interested in an original knob with upgrades working parts.....
      • upsrod
        • Feb 2010
        • 320
        The knob shown is a Genuine H-D accessory part #91690-49...so not correct for your '41. The original knob is right below it!
        • eubanks
          • Aug 2017
          • 9
          Awesome. Thanks for helping me clarify. I am assuming that it replaces the screw? As far as a replacement shaft is concerned, is the V-twin component any good?
          • Rooster
            • Mar 2009
            • 543
            There are replacement rods fitted with PEEK tips that invisibly solve the problem.
            V-Twin is not the solution.
            • Rollo
              • Nov 2008
              • 599
              Carl Olsen (Carl's Cycle Supply) for sure sells the peek tipped rod assembly and I have installed 4 on my bikes and they work great. You don't need to crank down too hard as the peek material seals well. Also you might want to make sure your needle and seat and float are functioning properly. Especially check the amount of play between the fingers on the float lever and the needle top. Check and set that before you set the float height or your never going to get it right. I used to go in the garage and smelled of gas all the time. Not so now!
              Carl sells the kit for around $100 but everything is brand new and includes the fuel valve, brass washers, peek tipped rod and shut off cap. All you need to do is remove your old stuff and replace it with the new and instead of the screw to hold the cap install your knob. You'll be glad to did!
              Tom (Rollo) Hardy
              AMCA #12766
                Eubanks!
                Five minutes re-cutting the original shut-off shaft on a lathe with the toolpost set at 45º (giving a 90º point) is by far the simplest and cheapest solution.
                The original metal tip will wear longer than PEEK, I assure you.
                PS: I'm selling PEEK scraps at $.25 a gram, if anyone needs some for a project.
                • RichO
                  • Dec 2001
                  • 903
                  Not if the seat is bad! Carl's is complete and does the job.
                  DrSprocket
                  • eubanks
                    • Aug 2017
                    • 9
                    thank you all so much for the feedback. I have sent Carl's an email and will contact them tomorrow.
                    • eubanks
                      • Aug 2017
                      • 9
                      Tom (Rollo) Hardy
                      AMCA #12766
                      Thank you sir! I do also have issue with the carb I need to get sorted.
                        The OEM seat is soft brass, Rich...
                        The OEM shaft tip is steel.
                        Its your money. Spend away!
                        PS: Wanna buy some PEEK?
                        • wideglide38
                          • Jul 2008
                          • 656
                          Carl's Cycle supply quoted me $225 for a peek set back in 2014. Maybe prices are lower today?
                          William Edwards, AMCA #10035
                          • Rollo
                            • Nov 2008
                            • 599
                            I bought mine form him at Oley a couple of years ago and some friends just bought some at Wauseon this year and they were $100.
                            Tom (Rollo) Hardy
                            AMCA #12766
                            • RichO
                              • Dec 2001
                              • 903
                              That's all well and good Tom if one of the issues isn't something went between the two and scored the seat.
                              DrSprocket
