Serial number ?? 47FL12514 - is it really or fake
  • JP66
    • Dec 2015
    • 7
    Too many scams, this one looks so good bUT, the s/not has me wondering. Experts please comment on photos. Thank you!
    kn23.jpgkn11.jpgh
    • 4790
    That number looks fine, a couple hundred over mine and close to the end of production!
    • JP66
      • Dec 2015
      • 7
      HI Robbie, thanks for your reply. Maybe you can help me understand this. Combined production in 47 was 11648. So how is it possible to have a legit serial number in the 12xxx. Am I missing something?
      Thanks again
        • 4790
        Yes, you are missing the fact that the numbers started at 1000. So add that to your total.
        • JP66
          • Dec 2015
          • 7
          Ahhh, yes well then. Thank you again
          • knucklehead 61
            • Sep 2016
            • 353
            numbers look fine.
            lots of repop & incorrect parts on that bike.
            it would be a good rider though, just not a amca judgeable bike.
            • JP66
              • Dec 2015
              • 7
              Thanks Knuck, I realize its not pure, good price, starting point.
              • knucklehead 61
                • Sep 2016
                • 353
                if it's not under 30k I would keep looking.
                looks like it might have panhead jugs on it...to match the panhead engine guard.
                • 36 knuck man
                  • Dec 2009
                  • 294
                  Good numbers
                  • JP66
                    • Dec 2015
                    • 7
                    Seller claims motor, frame springrr and wheels are orig.$17.5
                      Not all of the motor, JP66!
                      I'd knock a grand off its value just for the O-ring manifold conversion, maybe more, as that often did damage.
                      Since you can see the fuel filter, I suspect there is no carb support, so the machine isn't even intact.
                      Good project though, for somebody with lots of expendable cash and time...
                      PS: Usually nothing annoys me more than a clutch pedal stuck in the air;
                      But the routing for the advance control coil might.
                      PPS: The routing of the sparkplug wires suggest it hasn't run much at all.
                      That's probably a good thing.
                      • knucklehead 61
                        • Sep 2016
                        • 353
                        17.5 is a great price for a running knuckle, even if it is a bit of a frankenknuck.
                        making it totally correct would break the bank, but for a rider it has the look of a nicely refurbished bike.
                        you certainly won't get hurt buying it for that price.
                        • JP66
                          • Dec 2015
                          • 7
                          Learning, thanks for the insight
                          • chopsickle
                            • Oct 2013
                            • 34
                            My 47 is 12391. Now I've seen 3 ohv's built after mine ! I have a question, though. On a motor built that late, what should the date codes on the trans case, lid, and covers be around ? Mine are august/september of 47. Seems too close to 48 production to me.
                              • 4790
                              Two things to keep in mind. '47 was a really big year for H-D and production ran longer than normal to fill all the orders. There was also the push to use up as much inventory as possible. I wouldn't worry a bit about it.
