I have the pictured taillight shell for my 1939 project but have a question regarding the bar inside and the apparent lack of penned bar heads on the outside.
The shell looks OEM in every way to me and it does not look like a 1942-1946 style that has had the screw holes pounded out and welded. No sign of that at all from the inside. There is evidence where someone welded up the ever present splits at the top and bottom but that doesn't come close to where the screw holes would be. There is simply no sign of the bar from the outside. Could the heads have been polished off? There is NO SIGN at all of them. Not even a microscopic seam. Did they ever friction weld them in place?
Your thoughts please.
Mark Masa
Mark Masa
