Oil??
  • #16
    I was in the desert on the little 68T100R burning up some 20/50 weight from earilier in the season(cool). I was down right -forkin hot. So I dumped straight 70 on top of that. The viscosity of 70 is almost a gel - it's real entertaining just pouring it. Bike ran like a top. Nice and quite for obvious reasons.
    Some NAPA carry 60, 70 and 80 weight.
    Who cares what type. Keep your 50 clean.
    • #17
      I am just running HD 50 weight in mine and use the same for the tranny.
      Dont know if it was the 60 weight that I used for a change, but the oil was coming out of the rocker tins. I guess it finds the easiest way out, adjusted it a little and went back to 50 weight.
      Hope it works.
      d.
      • #18
        It's hot here in the South, so I use 60 weight in the summer, 50 in early spring and late fall. Either H-D or Rev-Tech.
        Lonnie
        • #19
          Thank you Lonnie,
          I was starting to get worried that I was using the wrong viscosity. Here in Oklahoma where the temps are usually hovering around 100 every day for two months during the summer I use HD 60 weight. In the fall (mid to late october) I go back to 50 weight. Glad I'm not the only one.
          Jim
