Spark plug leaks
  • pan620
    • Oct 2016
    • 223
    Spark plug leaks
    I have two different knucks around the shop and while pressure testing one of the manifolds for leaks I found the rear spark plug leaked bad around the seat area, swap a new plug in with the same outcome, tried the other engine with same results. Front ones on both engines seem fine, any thoughts? Thanks Dave
  • 1950Panhead
    • Jun 2010
    • 343
    Are you using D16 ?
    There is a seal ring on the plug.
    The seal ring is shot or you have a head defect, check both.
      Dave!
      I cut oversize seal washers from PEEK when they can cover the blemish or crack. And of course, I cut different thicknesses for indexing as well.
      • pan620
        • Oct 2016
        • 223
        Yes I have been using D-16 plugs but tried other brands,(New) with same results.I do not see a crack or blemish in either head but i dont see as good as I use to. Tom I will be in touch with you soon, Thanks
        • pan620
          • Oct 2016
          • 223
          I tried one of the Peek seals I got from Cotten on one of the heads and all is well, no leaks! Hopefully with a little more time I will have it running like new.
