Hello,
I'm building my first knucklehead engine from pile of parts, and I would like to get all the trick and tips that is needed to get a good runner.
Now I would like to know if the original oil circulation system is perfect or should there be some modifications done?
For example, my ULH I made a groove for pinion shaft bushing to allow oil go all the time to the crank pin. Seems like it was a good improvement. Is that good with knuckle as well?
How about governor system which by passes oil to gear case when engine has slow rpm's. To use it or not?
Breather gear, is original hole for vacuum enough, or should there be S&S type where's rather long hole instead of round one (longer time for vacuum to pushrod tubes)?
In my valve covers there's not small holes for get air sucked -> should I drill? Size and position?
Type of push rod tube seals? Cork or silicon?
Anything else?
Maybe there's FAQ somewhere, I didn't find it...
Thank you,
Antti
Anything else?
Thank you,
Antti
