Speedometer Cable
  • billpedalino
    • Mar 2005
    • 1096
    Speedometer Cable
    Because I'm thinking about having my '47 FL judged this year, I'm finally attending to all of the annoying things I must correct in order to try to make it to Junior-First (it's not a fresh restoration). To that end, my speedometer never worked. After disassembly I notice that the Speedometer head works and the problem is the aftermarket cable; the outer cable is 36" long whereas the OEM outer cables were 35-3/4". As best I could measure, the repro. inner core is slightly under 36-3/4" as opposed to the OEM length of 36-21/32". As a result, the speedometer end of the core doesn't engage the square drive in the speedometer head.
    AND THE QUESTION IS: Is anyone making correctly-sized, Cadmium-plated speedometer cables??
    Thanks and Happy Easter to all!
    Bill Pedalino
    Huntington, New York
    AMCA 6755
  • jstraker
    • Oct 2013
    • 59
    Hi, Bill. You could ask Ralph Dollarhite - he made a nice cable for my 1950 FL. Contact info I have for him is: recyclehd@yahoo.com. On another forum his phone number is given as 703-472-6886.
    Cheers, and happy Easter to you too!
    Justin
    • 1950Panhead
      • Jun 2010
      • 343
      John Bordas has the 35.75" speedo cables.
      • billpedalino
        • Mar 2005
        • 1096
        Thank you gentlemen.
        Bill Pedalino
        AMCA 6755
