M5 Linkert advice needed
  • MMasa
    • 1192
    I'm working on a 39 knucklehead and need to build some consensus regarding the correct attributes of a circa 1939 M5 Linkert.
    I've read conflicting things regarding the cast 4 vs stamped 4 on the side as well as when the carbs went from 4 line to 3 line. Finally the finish of the carb. Nickel? Cadmium? Painted?
    According to Palmers 2nd edition, ALL pre-1940 M5's are 4 line, nickel plated and have the 4 stamped into the side.
    Into the wilderness declares that only early/mid 1936-1937 M5's had the stamped 4 and that 1938-1939 M5's had the cast 4.
    I have been told that only 1936-37 carbs were nickel plated and that it then went to cadmium.
    And finally, I have seen a 3 line M5 but it also has a cast 4. Is this a doctored M55?
    Thanks for your opinions.
    Mark
    Mark Masa
    www.linkcycles.com
    Mark!
    The bodies were dull "Watts" nickel; By '39, small hardware was a mix of nickel and cad.
    I have never encountered one with a cast 4.
    • 36 knuck man
      • Dec 2009
      • 294
      Mark, I just posted a reply with picture on cai, thanks, Larry
        Golly Larry,
        I would like to see the pic too!
        • BigLakeBob
          • 2768
          You can see it over there without logging in.
          Golly Larry,
          Bob Rice #6738
            The M5 carb is now being reproduced in Europe and maybe they have the cast 4.
            • 36 knuck man
              • Dec 2009
              • 294
              Here ya go Cotton
              • koanes
                • Apr 2003
                • 656
                My M5f, original to my 39 EL former CHP motorcycle has cast in #4, with # 3 stamped in under low speed needle holder. No sign of nickel. I also have nickel plated M5 with the 4 stamped into a square. The # 2 is stamped in under needle holder.
                Kyle Oanes AMCA # 3046
                  Thanks Larry!
                  (After the way I was treated on that forum, I don't even want to give Buzz a cookie.)
                  Methinks that may be the wrong HS needle knob, and LS knob screw,.. but I've never been trusted with a two-bolt.
                  The plating is certainly modern.
                  • 36 knuck man
                    • Dec 2009
                    • 294
                    Thanks Cotten, I appreciate your info, Larry
