Spot light gaskets
  • Snakeoil
    • Jan 2008
    • 219
    Spot light gaskets
    I've been looking around the internet and so far have not found a thing. Does anyone make repop rubber gaskets for the adjustable spotlights?
    I have one soft rubber one that is melting along about 10% of the diameter and one good flat one. Flat one I can make if necessary. And I have an ideal how to make a replacement for the soft rubber one. But it would be a lot easier to just buy replacements.
    Rob
    Regards,
    Rob Sigond
    AMCA # 1811
    Rob, it's easier to look at McMaster supply. They will have a gasketing that is close if not the same thing. Bob L
    • Snakeoil
      • Jan 2008
      • 219
      Yes, I use them quite a bit. The gaskets in question are actually molded gaskets with a T-shaped cross-section. I was hoping someone made them. I do have a idea on how to come close to the original.
      Rob
      Regards,
      Rob Sigond
      AMCA # 1811
      • Carl Olsen
        • Jan 2002
        • 261
        I get mine from Custom Chrome.
        Carl
        • Snakeoil
          • Jan 2008
          • 219
          Carl
          No sign of them in their on-line catalog. V-twin has them and Drag specialities said they have them. Theirs are the V-twin products and you have to buy a bag of 10. So, made my own from 1/8" medium density black closed cell foam. Should be fine. Had to make one for the headlight, too.
          Do you sell them, Carl? The pic on the V-twin site made them look like junk. But the photo could be incorrect. Original has a T-shaped cross section. I now realize that the flat gasket I found in one of the spotlights must've bebe something the PO had added.
          Regards,
          Rob
          Regards,
          Rob Sigond
          AMCA # 1811
          • billpedalino
            • Mar 2005
            • 1096
            I just bought a bag of 10 from V-Twin and they worked fine on the OEM spotlights on my '47 FL
            Bill Pedalino
            Huntington, New York
            AMCA 6755
            • Snakeoil
              • Jan 2008
              • 219
              Bill, are they the correct t-shaped cross section?
              Rob
              Regards,
              Rob Sigond
              AMCA # 1811
              • billpedalino
                • Mar 2005
                • 1096
                Rob,
                I don't remember, but they look fine installed. I'll look when I get home tonight and let you know...
                Bill Pedalino
                AMCA 6755
                • upsrod
                  • Feb 2010
                  • 320
                  Bill's in Pa. sells them but they are a denser rubber then the originals!
                    Gosh Folks,
                    I always got them from the John Deere dealer.
                      Gosh Folks,
                      It is hard to find a John Deere dealer in Los Angeles. :-)
                        Allis Chalmers? Farmall? Case? Oliver? ....Ford?
                        Nevermind.
                        .....Cotten
                          Gosh Folks,
                          Do you have a part number?
                            • 4790
                            All the tractor restoration joints list them. Common aftermarket part. Guide lights were used on tons of stuff. The lenses are wrong and the housings have stems rather than adjustable bases, but the bezels (painted) and the lens gaskets are common to H-D types. Some lenses will interchange, but some have red pilot lights incorporated in them.
                            • Snakeoil
                              • Jan 2008
                              • 219
                              JD right around the corner and TSC not much further. I embarrassed that it never occurred to me.
                              Rob
                              Regards,
                              Rob Sigond
                              AMCA # 1811
