47 knuckle head valve specs
  • 46CHF
    • Nov 2009
    • 68
    I am currently redoing a set of 47 knuckle
    heads.. with kibblewhite valves , valve guides and a set of Eastern Springs. any info on Installed height, installed spring pressure, stock valve lift, etc. would be greatly appreciated
  • knuckleheadtim
    • Jan 2008
    • 141
    I've been setting the valve height at 1.560" above the shoulder. The Pan spec of 1.500" is too tight with stock valve guides, and there's a risk of bottoming on the guide. The Kibblewhite guides are shorter, so it's not so much of a risk. Lift is .373" as the rockers are 1:1 ratio. The free length of the springs is listed in the text of the service manual.
