Looking to trade: 1938 BT frame for 1939 BT frame
  • MMasa
    • 1192
    Looking to trade a very nice 1938 Big Twin Frame for a similar condition 1939 Big Twin Frame.
    Checking the hallmarks against Palmers new edition, it appears my frame is a 1938.
    The frame has all castings / forgings un-molested. The tool box mount, and rear fender mount behind the transmission have been repaired / replaced by an expert frame man and is all strait an ready to go. I would rate the condition of this frame as a very solid 9 out of 10.
    PM or email me if interested.
    The frame is trade only and not for sale.
    Mark Masa
    www.linkcycles.com
  • MMasa
    • 1192
    I should also add that I'd be more than happy to just buy a 1939 frame if a trade doesn't work for you. If it is a purchase and not a trade, then the 1939 frame does NOT have to be in the same very good condition as my 1938 frame.
    Mark
    Mark Masa
    www.linkcycles.com
    • 48hdbob1
      • Nov 2009
      • 111
      I'd be more than happy to buy your '38 frame when you buy a '39. thanks-Bob
      • Steve Little
        • Apr 2008
        • 915
        Mark. Is your 1939 engine early, mid, or late?
        Regards Steve
        Steve Little
        Upper Yarra Valley. Victoria.
        Australia.
        AMCA member 1950
        • MMasa
          • 1192
          Steve
          The VIN is in the 3400's (39EL34xx). Is that mid or late?
          Mark
          Mark Masa
          www.linkcycles.com
          • LJH
            • 61
            Mark, I would call that, mid to late. The highest, vin. I have seen is 39EL39xx
            that was the op bike, with the shipping crate, that sold on e-bay a few years ago
            Regards, Lee
            • Steve Little
              • Apr 2008
              • 915
              Hi Mark. Early 1939 still used the 1938 frame with the number 3 revision neck and the welded cap, axle carrier. I was checking to see if your engine may have suited your frame, but it is a couple thousand outside acceptable range.
              Good luck on the search.
              Steve Little
              Australia.
              AMCA member 1950
              • dennis49
                • Feb 2003
                • 13
                Hi Mark did you see my pm to you ,It's a late 39 frame.
                let me know.
                dennis49
                • MMasa
                  • 1192
                  Dennis
                  Just saw it and sent a PM back.
                  Mark
                  Mark Masa
                  www.linkcycles.com
