Panhead cylinders on a Knucklehead
  • DANPATCH
    • Apr 2009
    • 313
    The deck height on a 74 Panhead cylinder and the 74 Knucklehead cylinders are different when you measure between the base gasket and head gasket.So how did they work when they use to put pan cylinders on a Knucklehead.
  • Hollywood
    • Mar 2011
    • 223
    "Stroker" plates under the cylinder to make up the difference and re-position one head bolt.
    • Hollywood
      • Mar 2011
      • 223
      Like so...
