oil pressure switch
  • poorbiker
    • Mar 2013
    • 170
    oil pressure switch
    Who makes a good replacement oil switch, short of the imports.........
  • vph-d
    • 1088
    I'm using two of the Evo style oil switches on Panheads. They work ok, but are taller than than the original switch.
    VPH-D
    • Sargehere
      Member since 1972
      • Jul 2006
      • 971
      Go down to the auto parts store and get a "PS15" oil pressure switch. Cheap, works perfectly. Problem solved.
      Gerry Lyons #607
      http://www.37ul.com/
      • rwm
        • Dec 2006
        • 1302
        probably an import
        rob ronky #10507
        www.diamondhorsevalley.com
