Front end Center Stand
  • Sidehacker
    • Sep 2012
    • 235
    Does anyone make the spring pt# 3061-24 or. Front stand stud pt# 3640-31E or have the dementions of the stud length. Did they ever come stock or were they just an accessory and has anyone had any experience using one.
    THANKS
    FNA
    • 4790
    This stand? They were common on Export models, but rare in the US. They can have ground clearance issues also. I can measure and give you specs on the studs and assorted parts. They were standard on WLCs.
    • Sidehacker
      • Sep 2012
      • 235
      You have come to my aid before, lol, thats the exact picture I wanted to see. That actually looks like a rear stand on the front. The one I have is a repo but looks like the one in book. It came in a box of parts I got .I say its a repo cause its powdered and the metal looksbrand new with sharp edges and the rivets dont look as uniform as factory.
      I would definitley like the measurements of the stud. If its the same as the one that just comes on the fro t fender except for length of threaded stud that would be only measurement i would need. Also any spring info would be appriciated.
      One other question , you said there are ground clearance problems . Is that while its in up position, or is it some other way please explain .
      FNA
