36EL Rear Brake Foot Pedal Mounting Stud
  • 46EL
    • Apr 2009
    • 728
    Does anyone out there know if someone makes a repop 36 Brake Pedal Stud with the nut that bolts on the frame mounted bracket?? Thanks. 46EL
  • sirhrmechanic
    Vigilis
    • Dec 2010
    • 1147
    Based on the side cover from a post earlier this week, there is probably an original on eBay for $2250!
    Have you called Harbor Vintage? If anyone has one or knows where it's repro'd, it will be Dave.
    Cheers,
    Sirhr
    • diesel55
      • Jul 2011
      • 262
      pedal
      hello.. have the stud repair kits nos. cut off the part you peen over, replace with threaded stud. 14.00 plus 3.00 shipping
      • Carl Olsen
        • Jan 2002
        • 261
        Colony makes the stud you need, if you can't get it at your local shop contact me.
        Carl
          Carl
          I find this one on the Colony Web Site. But I don't see one for a '36EL.
          Foot Brake Lever Stud
          OEM style, heat treated and precision ground stud. Fits 1937-1957 Big Twins
          and 1939-1973 45's. Complete with mounting hardware.
          Stock No. 2316-5 Stock Size
          Stock No. 2310-5 Oversized to 23/32 for those "sloppy" brake levers.
          Open up brake levers with 23/32 reamer for a perfect fit,
          available at your local tool supply company.
          • 46EL
            • Apr 2009
            • 728
            Thanks guys for your replies. Diesel55 I sent you a PM, 46el
